LabWindows/CVI
Mixing of two tab's data when tabs visible option is Unchecked (Urgent) ?
Hi All
I have a problem with tab, when tab visible option is checked it works properly but actually i have to uncheck this option due to my application requirement.
When i uncheck this option in tab properties or set attribute in programming, tab does not shift and the next tab's data is displayed in the previous tab. In short the data of both tabs is mixed together.
For clarity i have attached screenshots
Picture 1.bmp and 2.bmp indicate the scenario when tab visible option is checked and 3.bmp is taken when this option is unchecked.
How to cater this problem ?
Regards
umer
(2,971 Views)
I can't reproduce this... can you attach a simplified program that shows this behavior?
(2,961 Views)
