LabWindows/CVI
Module cvirte.msm could not be found
i am using LabWindows 8.0. When i will create a distribution, in the drivers & components tab, i became the following error message when i check the module dependencies: "Module cvirte.msm could not be found". I will only distribute the Standard Run-Time.
What is it wrong?
Kind regards
Jürgen
(3,883 Views)
Hello Jurgen,
This is a known CVI issue on non-English versions of Windows that will be fixed soon.  The modules cannot be found, because CVI expects the modules to be found in a directory named "Common Files\Merge Modules" under your Program Files directory, and on a non-English version of Windows, the name "Common Files" is localized.
There are two workarounds.  One solution is to manually add the needed modules (cvirte.msm, etc) to your distribution from their actual location (Programme\Gemeinsame Dateien\Merge Modules on a German OS) via the "Add Additional Module" button on the Drivers and Components tab.  Alternatively, you can create the path Common Files\Merge Modules under your Programme directory and copy all the contents of Gemeinsame Dateien\Merge Modules over to the new directory.
As a side note, you may notice that CVI will also always try to include IviPaths.msm in your distribution.  This is only important if your distribution installs any files to the IVI Std Root directory, and can otherwise be ignored.
I appologize for the inconvenience.
Mert A.
(3,875 Views)
Accepted by JürgenS
It works fine!
Many thanks and
kind regards from Austria
Jürgen
(3,863 Views)
