LabWindows/CVI
Mouse events don't work on a button from a panel ran in a DLL
Daniel, that was my point. You must call QuitUserInterface from the same thread that called RunUserInterface. Therefore, you should not call QuitUserInterface directly.
Luis
Message 11 of 14
(1,224 Views)
Thanks Luis for making it clear.
I'll use PostDeferredCallToThread(), but either way I have my problem solved.
Daniel Coelho
VISToolkit - http://www.vistoolkit.com - Your Real Virtual Instrument Solution
Controlar - Electronica Industrial e Sistemas, Lda
Message 12 of 14
(1,213 Views)
Daniel,
Apologies for the misleading post.
I forgot the point that your panel is loaded by a thread other then DLL's main thread.
So Luis is -of course- correct in his suggestion of using PostDeferredCallToThread.
S. Eren BALCI
IMESTEK
Message 13 of 14
(1,210 Views)
No worries.
Everything is working well and PostDeferredCallToThread() will be my next upgrade.
I appreciate everyones effort.
Daniel Coelho
Message 14 of 14
(1,208 Views)
