My text messsage is not visible during my program works
I have write a programm, to write a file format in an other.
The files are so big that the programm work very long. So I made a text message  that show the program is still working.
In the beginning was working well. But now the text messages is no longer displayed.
I have no idea what the problem is.
some code:
int CVICALLBACK ReadCallback (int panel, int control, int event,
		void *callbackData, int eventData1, int eventData2)
	int iConfiguration;
	switch (event)
		case EVENT_COMMIT:
			SetCtrlAttribute (panelHandle, PANEL_TXTMSG_Load, ATTR_VISIBLE, 1);
			GetCtrlVal (panelHandle, PANEL_Dataset_Conf, &iConfiguration);
Function_Worker(iConfiguration); SetCtrlAttribute (panelHandle, PANEL_TXTMSG_Load, ATTR_VISIBLE, 0); break; case EVENT_LEFT_CLICK: break; } return 0; }
The function_worker does made nothing with the GUI but it works with a DLL. Is this a problem?
Do you have any ideas?
(3,298 Views)
Accepted by susay
When your program executes in a callback function or in code that does not call RunUserInterface or GetUserEvent, LabWindows/CVI does not process user interface events. Functions that are overly time-consuming can "lock out" user interface events. To allow LabWindows/CVI to process events, call ProcessDrawEvents.
(3,296 Views)
Somewhat more elaborate I'd suggest to modify your code as follows:
case EVENT_COMMIT:
    ProcessDrawEvents ();
    break;
(3,291 Views)
Thank you very much. With "ProcessDrawEvents ();" it works perfectly.
(3,285 Views)
