LabWindows/CVI
NI-488.2 missing
Accepted by topic author ACowans
The NI LabWindows/CVI 9.0.1 Base Package is a separate disk. It is not on the driver DVD. When you are prompted, you will have to swap out the driver DVD and insert the CVI 9.0.1 disk.
Mert A.
Message 11 of 13
(1,647 Views)
Alright, I tried to create a distribution again and when it asked for the Base Package I switched that disk in. It got to the end and send there was an error and not all the files were copied over. I took the disk out and put back in the Driver DVD and tried to build yet another distribution. This time it went perfectly. I don't fully understand what happened for the distribution process to work, but I'm happy it finally did. Thanks so much for your help!
Tony
Message 12 of 13
(1,642 Views)
Let me know if you continue to have problems building distributions.
Mert A.
Message 13 of 13
(1,638 Views)
