LabWindows/CVI
NI 6602 Write and Read Frequency
Hi all ,
I Have NI 6602 timing card and i'm trying to use it in order to write and read using the
DAQmxWriteCtrFreq (taskHandle1, 0, 1, 10.0, DAQmx_Val_GroupByChannel, &freq, &duty, &writtenVal, 0);
and
DAQmxReadCounterScalarF64(taskHandle2,10.0,&dataVal,0);
what i'm trying to do is to write to ctt0 and to read from ctr7 ( they are crossed in the card )
i'm having a bit problems with that can some one give me a tip on how to do it properly ?
just write freq to ctr0 and read freq from ctr7.....
Kobi Kalif
Software Engineer
(3,675 Views)
After a few things i only need to make an output counter frequency...
but i just didn't make any progress any one knows how ?
Kobi Kalif
Software Engineer
(3,664 Views)
Accepted by Kobi_K
You should have the following sample installed on your PC that may help you in this task: DigPulseTrain-Cont.prj (it could be located in \program files\National Instruments\CVIx\samples\daqmx\counter\generate pulse folder)
(3,654 Views)
