04-30-2014 11:45 AM
For some reason the NI-DAQmx installer refuses to install LabWindows support. It says it only works with LabWindows 7 and above... I'm using LabWindows 2013 (version 12). In fact, the installer won't let me select anything.
I need to get LabWindows support installed. Any ideas?
FYI: I have Measurement Studio installed also. Windows 7 64bit. My applications are compiled to 32bit though.
05-01-2014
01:07 PM
- last edited on
09-14-2026
08:25 AM
by
Content Cleaner
I believe the reason that you are running into this issue is that DAQmx 9.6.2 is not compatible with LabWindows/CVI 2013. The following is included on the DAQmx 9.6.2 download page:
I would recommend installing DAQmx 9.8, which is compatible with LabWindows/CVI 2013, and can be found on our website here:
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288374
02:12 PM
- last edited on
09-14-2026
08:26 AM
by
Content Cleaner
Hello WayneS1324,
This configuration should be working. After some investigation over here, we were able to install NI-DAQmx 9.6.2 support with LabWindows/CVI 2013 installed. Have you tried installing NI-DAQmx 9.6.2 by itself? You can find the download page here: NI-DAQmx 9.6.2.
Let me know if the standalone installer still does not allow you to select LabWindows/CVI Support.
Daniel
