LabWindows/CVI
Trying to get a handle to an object using CVI_ActiveApp, but it opens a new CVI everytime it runs. Is there a way to get a handle to an object without it opening up a new CVI?
I'm trying to get a handle to an object using CVI_ActiveApp. It works, but it opens a new CVI application when it is run using the command line. Is it possible to get a handle to an object without a new CVI application opening up?
(4,397 Views)
In the help documentation for the CVI_ActiveApp function, it states:
"If the server application is already running, this function may or may not start another copy of the application. This is determined by the server application."
http://zone.ni.com/reference/en-XX/help/370051P-01/cvi/usermanual/actxappactiveapp/
I don't believe you have control over whether or not a second instance is started.
(4,358 Views)
I wonder if this question is somewhat related to this other one.
(4,349 Views)
