LabWindows/CVI
NI-USI Install
I want to install a recent (not necessarily the newest) version of NI-USI.  The version in mind is 1.9.0.
When I select this in the Drivers & Components tab on my distribution build file,  and then perform a build, I get an error:
Some of the installers selected are not on this computer...
Using the "Change Source" button, I point to a file that I know contains that component (on my local drive).
Any idea why I am getting the error?
All thoughts are appreciated.
Jacob
(6,823 Views)
Hi Jacob,
Is there any error code associated with your message? I believe that this behavior is due to the way in which USI is being added, or not added as the case may be. I'll post this Step-by-Step Guide as reference for building installers. See if you can verify that it was included as part of the distribution.
Cheers,
KyleP
(6,806 Views)
