LabWindows/CVI
setting memory block with offset
HI,
i am trying to use memcpy function with offset in my application. i want to copy bytes from one buffer to the other starting from 3rd location. i want to leave first 2 bytes as header info. Can somebody help me on this please?
(3,584 Views)
Just add the offset to the buffers adress ( which is identical to the buffer itself in C ) Something like
memcpy ( target+2, source+2, sizeof( source )-2).
And make sure that the target buffer is big enough.
(3,578 Views)
