LabWindows/CVI
NI Update Service: communication problems
Hi tobima,
We have servers all over the world, so I wouldn't expect your download rates to be slow just because you're in China, especially since both of the updates you mention are pretty small. Getting a log would be the most helpful thing to do. Then we can see if it's really a download problem or something else entirely. Please close NI Update Service, discard your current session, and run it again from the command line with -log, like described in my earlier post.
LaRisa Mohr
Staff Product Support Engineer - NI Update Service
National Instruments R&D
Message 31 of 35
(2,318 Views)
Thank you for your quick reply! I have now downloaded version 2.1.1 of the updater (using the download link you postet earlier) and tried to generate a log file, since I couldn't get it working with the old version. The interesting part about the log file is the following:
[2012-12-06 13:29:40Z] Starting worker thread Download Updates.
[2012-12-06 13:29:40Z] UpdateEngine.Download: Begin
[2012-12-06 13:29:40Z] HTTPResumeDownloadManager.DownloadItem: Downloading to C:\ProgramData\National Instruments\Update Service\Installers\f2-Patch für LabVIEW 2011 SP1 für 32-Bit-Windows (Runtime-Engine)5ce6cf3452a1d118bb69d5756f3efcd6.tmp
[2012-12-06 13:29:40Z] UpdateEngine.Download: End
[2012-12-06 13:29:40Z] HTTPSingleFileDownloader.Download: calling pipeline.DownloadStart() for C:\ProgramData\National Instruments\Update Service\Installers\f2-Patch für LabVIEW 2011 SP1 für 32-Bit-Windows (Runtime-Engine)5ce6cf3452a1d118bb69d5756f3efcd6.tmp
[2012-12-06 13:35:26Z] HTTPSingleFileDownloader.Download: DownloadCheck returned an error!
[2012-12-06 13:35:26Z] HTTPSingleFileDownloader.Download: calling pipeline.ResetPipeline() for C:\ProgramData\National Instruments\Update Service\Installers\f2-Patch für LabVIEW 2011 SP1 für 32-Bit-Windows (Runtime-Engine)5ce6cf3452a1d118bb69d5756f3efcd6.tmp
[2012-12-06 13:35:26Z] WebPipeline.ResetPipeline
[2012-12-06 13:35:26Z]    calling WsUdClose 4
[2012-12-06 13:35:26Z]     done - setting pipelineId=0
[2012-12-06 13:35:26Z] HTTPResumeDownloadManager.downloader_DownloadedComplete: Begin
[2012-12-06 13:35:26Z] HTTPResumeDownloadManager.downloader_DownloadedComplete: downloader.IsError() returned true!
[2012-12-06 13:35:26Z] UpdatePluginMSI.MonitorDownloadThread: this.downloader.IsError returned true!
[2012-12-06 13:35:26Z] UpdateEngine.Download: Begin
[2012-12-06 13:35:26Z] UpdateEngine.Download: End
[2012-12-06 13:35:26Z] UpdateServicePresenter.DownloadUpdates: Error downloading!
[2012-12-06 13:35:26Z] Finished worker thread Download Updates.
[2012-12-06 13:35:26Z] UpdateServicePresenter.DownloadFinished
[2012-12-06 13:35:26Z]    There was an exception. Do not install the updates.
[2012-12-06 13:35:26Z] An error occurred in worker thread Download Updates: NI.UpdateWizard.Common.UpdateServiceException: Downloading errored
[2012-12-06 13:35:26Z] ***ERROR: Downloading errored
[2012-12-06 13:35:56Z] UpdateServicePresenter.BeforeClose: Determine whether to prompt to confirm.
[2012-12-06 13:35:56Z]     Not downloading but there are updates in an incomplete state. Show the confirmation dialog.
[2012-12-06 13:36:08Z] ----------------------------------------------------------------------
Maybe the cause of this problem is that I use a 64bit Win7 and the update is a 32bit update. Maybe. But then I wonder why the updater starts the download in the first place.
I tried to download the second update only. This lead to the same error. I have attached my logfile to this post..
Can I download the update(s) manually or could it be that I don't need them at all? I'm using DIAdem version 11.3.0f4563 TDM.
Message 32 of 35
(2,303 Views)
This is the second log file.
Message 33 of 35
(2,296 Views)
Well, it is pretty clear that the files fail to download. Unfortunately, I can't understand why. For a Windows 7 64-bit machine, Update Service should have permission to download to that location, the file path isn't too long, and it's not a partial download because Update Service never even gets to running a checksum on the downloaded file.
You can try downloading these updates manually from ni.com. The server path is the same whether you download from ni.com or through Update Service, so I'm curious to see if ni.com is successful. Here are the pages where you can get the two updates you've mentioned:
LV 2011 SP1 f2 RTE: http://joule.ni.com/nidu/cds/view/p/id/2897
Security Advisory 5Q5FJ4QW: http://joule.ni.com/nidu/cds/view/p/id/2698
DIAdem includes the LV Run-Time Engine, which both of these updates patch, but I don't know to what extent the patches affect DIAdem users. It would probably be good to get the patches. Hopefully the manual downloads are successful.
LaRisa Mohr
Message 34 of 35
(2,279 Views)
I hope it is allowed to write a reply to this post, since it was marked as solved.
Unfortunatelly I see the same problem again, and I am not able to update my NI softs.
My system: Win7 64bit, fresh install of LabView 2012 Full version (SSP licence).
NI Update Service does not work, I tried to run it in Admin mode, also disableing Firewall, etc...
Here comes again the infamous error mssg.:  "An issue communicating with NI has occured...."
Here I paste the content of my log file, it shows error with "Errror updating Launch Condition Evaluator" . Regarding to the previous replies in this post, I thought this issue has been solved. But it looks like it is not...or something new?
For the reference, I have downloaded the newest version of Update service 2.2.1 from NI webpage.
Thanks for any help, I really need this update service,
Best Regards,
log.txt:
[2013-01-14 10:57:43Z] ----------------------------------------------------------------------
[2013-01-14 10:57:43Z] National Instruments Update Service
[2013-01-14 10:57:43Z] Command-line: NIUpdateService.exe  -log log.txt
[2013-01-14 10:57:43Z] SingleInstance.SingleInstance: Exception caught while constructing mutex. Assuming another instance is not running...
[2013-01-14 10:57:43Z] System.Security.Principal.IdentityNotMappedException: Some or all identity references could not be translated.
   at System.Security.Principal.NTAccount.Translate(IdentityReferenceCollection sourceAccounts, Type targetType, Boolean forceSuccess)
   at System.Security.Principal.NTAccount.Translate(Type targetType)
   at System.Security.AccessControl.CommonObjectSecurity.ModifyAccess(AccessControlModification modification, AccessRule rule, Boolean& modified)
   at System.Security.AccessControl.CommonObjectSecurity.AddAccessRule(AccessRule rule)
   at NI.UpdateWizard.Common.SingleInstance..ctor(String name, Uniqueness howUnique, ILogger logger)
[2013-01-14 10:57:43Z] NiLmClient DLL loaded successfully.
[2013-01-14 10:57:43Z] NiLmClient DLL unloaded successfully.
[2013-01-14 10:57:43Z] License Manager: Update Service is enabled.
[2013-01-14 10:57:44Z] UpdateServicePresenter.CheckForUpdatesPressed
[2013-01-14 10:57:44Z] Beginning the process of checking for and evaluating updates.
[2013-01-14 10:57:46Z] Pipeline is up.
[2013-01-14 10:57:46Z] Finished worker thread Ping Pipeline.
[2013-01-14 10:57:46Z] Starting worker thread Collect Information.
[2013-01-14 10:57:46Z] Collecting system information.
[2013-01-14 10:57:46Z] WebPipeline.ResetPipeline
[2013-01-14 10:57:46Z] Finished worker thread Collect Information.
[2013-01-14 10:57:46Z] Starting worker thread Check For Updates.
[2013-01-14 10:57:46Z] Querying ni.com for critical updates.
[2013-01-14 10:57:46Z] LaunchConditions.DownloadCatalog: Calling QueryPipeline
[2013-01-14 10:57:46Z]     Loading XML
[2013-01-14 10:57:46Z]     Done loading Xml
[2013-01-14 10:57:46Z] HTTPResumeDownloadManager.DownloadItem: Downloading to C:\Users\Andras\AppData\Local\Temp\tmpD1B1.tmp
[2013-01-14 10:57:46Z] HTTPSingleFileDownloader.Download: calling pipeline.DownloadStart() for C:\Users\Andras\AppData\Local\Temp\tmpD1B1.tmp
[2013-01-14 10:57:47Z] HTTPSingleFileDownloader.Download: DownloadCheck returned an error!
[2013-01-14 10:57:47Z] HTTPSingleFileDownloader.Download: calling pipeline.ResetPipeline() for C:\Users\Andras\AppData\Local\Temp\tmpD1B1.tmp
[2013-01-14 10:57:47Z] WebPipeline.ResetPipeline
[2013-01-14 10:57:47Z]    calling WsUdClose 3
[2013-01-14 10:57:47Z]     done - setting pipelineId=0
[2013-01-14 10:57:47Z] HTTPResumeDownloadManager.downloader_DownloadedComplete: Begin
[2013-01-14 10:57:47Z] HTTPResumeDownloadManager.downloader_DownloadedComplete: downloader.IsError() returned true!
[2013-01-14 10:57:47Z] Finished worker thread Check For Updates.
[2013-01-14 10:57:47Z] An error occurred in worker thread Check For Updates: NI.UpdateWizard.Common.UpdateServiceException: Errror updating Launch Condition Evaluator
   at NI.UpdateWizard.UpdatePluginLaunchConditions.UpdatePluginLaunchConditions.a(String A_0, String A_1, UInt64 A_2)
   at NI.UpdateWizard.UpdatePluginLaunchConditions.UpdatePluginLaunchConditions.DownloadCatalog(OptionsUpdateSearchType searchType, Boolean& cancelled)
   at NI.UpdateWizard.UpdateEngine.UpdateEngine.CheckForUpdates(OptionsUpdateSearchType searchType, Boolean& cancelled)
   at NI.UpdateWizard.UpdatePresentation.UpdateServicePresenter.i(Object A_0, DoWorkEventArgs A_1)
[2013-01-14 10:57:47Z] ***ERROR: Errror updating Launch Condition Evaluator
[2013-01-14 10:57:51Z] UpdateServicePresenter.BeforeClose: Determine whether to prompt to confirm.
[2013-01-14 10:57:51Z] UpdateServicePresenter.StopWorkers: Stopping workers
[2013-01-14 10:57:51Z] UpdateServicePresenter.StopWorkers complete.
[2013-01-14 10:57:51Z]     Not downloading. Continue closing.
[2013-01-14 10:57:52Z] ----------------------------------------------------------------------
Message 35 of 35
(2,213 Views)
