NI digital I /O 6501
Hello guys,
I am going to use NI 6501 I/O card to control RF switches (teledyne). I can control the switch but I could not read the indicator output of swtich. When I / O configuration like a input all pins are active. Also, when I connect to control pin of RF switch then the switch is going to work in input mode of I/O. I think in input mode, I/O gives voltage, so when I try to read RF switch output (indicator), the value is still "1". Is there any recommendation for test setup.
The test setup is drawn below.
Regards.
(937 Views)
Dear ozano,
Do you have any code written for this? If so please attach the file.
(808 Views)
