‎05-18-2014 11:55 AM
I am running CVI 2013 SP1 with debugging level set to extended.
I have changed a formatting parameter in a FmtFile function call and now receive this error. I am wondering why CVI cannot handle this error better, i.e., inform me about the line number... One may have more than just one Fmt function...
Solved! Go to Solution.
‎05-19-2014 02:13 AM
Hello Wolfgang,
Are you running the code in the Interactive Execution or as part of a program?
Thanks!
= Nelu F. || National Instruments.
‎05-19-2014 02:24 AM
Hello Nelu,
it's part of a larger program, no interactive execution, and the formatting involves "%s%d%s%d[b8]...."
The error occured after I replaced a 32 bit integer by a 64 bit value and misplaced the [b8] (i.e. after the first %d instead of the second...). So the error is o.k. but it would have been useful if CVI would have informed me about the relevant line...
‎05-19-2014 03:38 AM
Hello Wolfgang,
I tried reproducing the issue you've described and I received the following message:
I too tested with LabWindows/CVI 2013 SP1 (build 201), and I received the location information. Are you receiving a different message?
‎05-19-2014 04:26 AM - edited ‎05-19-2014 04:27 AM
Hi Nelu,
Thanks a lot for assistance!
Yes... I received exactly the message posted as subject... so what might be the difference? I am attaching my line of code and the error message popup below - the difference between your case and my case might be the length of the format string or the fact that there are several numbers involved in my case...??
‎05-19-2014 04:36 AM
I just realized that you have used long (32 bit) - whereas I have used long long int (64 bit)...
‎05-20-2014 01:48 AM
Hello Wolfgang,
I reproduced the error as you described it in the Debug64 configuration only. In the Debug configuration, the source location was specificed, so I have opened bug 472987 to track it. The issue appears to originate in LabWindows/CVI 2013.
Are you also seeing this issue in the Debug configuration? If so, could you please provide a sample?
Thanking you for your input,
‎05-20-2014 01:52 AM
Hello Nelu,
I am glad you could reproduce the issue, thanks a lot!
Indeed, I am using Debug64 configuration.
