LabWindows/CVI
NON-FATAL RUN-TIME ERROR: "Start.c", line 152, col 34, thread id 0x00000C7C: Not enough space for casting expression to 'pointer to struct'
I'm using LabWindows/CVI 8.5.
Who can tell me, what does it mean:NON-FATAL RUN-TIME ERROR:   "XXXX.c", line 152, col 34, thread id 0x00000C7C:   Not enough space for casting expression to 'pointer to struct' ?
I am trying to require a memory for my big structure with a malloc function and  i receive this error message. I can continue to run my programm, but i want to avoid this message in future. Does it mean, i have not enough stack memory for allocation or something else ? What should i do, to allocate memory without this error message?
Than you
(5,222 Views)
Could you post the offending code?
JR
(5,210 Views)
Here the code:
Well, the big structure Radio is realy big, is about 230 Byte in a empty state. But it does not matter, is not it? I think there is a problem with a memory reservation for a pointer for this structure.
struct Radio *RadioGruppen[20];  // global
void GenerateGroups(int GruppenStaerke, int GruppenIndex, int ZellenNr)
 int El = 0;
  RadioGruppen[GruppenIndex] = malloc(sizeof(RadioGruppen[GruppenIndex])); // on this line happens first time
  RadioGruppen[GruppenIndex]->ZelleNr = ZellenNr;
  RadioGruppen[GruppenIndex]->Gruppenstaerke = GruppenStaerke;
  RadioGruppen[GruppenIndex]->next = NULL;
  for(El = 1; El < GruppenStaerke; El++)
   ZellenNr++;
   RadioGruppen[GruppenIndex] = AppendNewElement(RadioGruppen[GruppenIndex],ZellenNr); // in this function i create with malloc
        //  function new elements and
        // append them to the
        // RadioGruppen[GruppenIndex],
the other header file:
struct Radio * AppendNewElement(struct Radio *lst, int ZNr)
    struct Radio *new_list_item= malloc(sizeof(new_list_item));
 struct Radio *cur= lst;       /* declare variable for parsing list */
 new_list_item->ZelleNr = ZNr;/* assign elem to list item*/
 new_list_item->next = NULL;/* thereisno successorto thenewelement*/
 if(lst==NULL)               /* if list empty*/
  return new_list_item;/* return new element*/
 while(cur->next!= NULL)/* otherwise parse list and search for last elem*/
  cur=cur->next;
 cur->next=new_list_item; /* append new element to the last element*/
 return lst;/* were turn the new list */
Thank you for the answer.
Message Edited by Boris1980 on 03-05-2008 08:54 AM
(5,204 Views)
I think the problem is in your malloc() statement. The item RadioGruppen[GruppenIndex] is a pointer (to Radio), so doing a sizeof on it will return 4 bytes. This is how many bytes malloc() will reserve. I suspect you intended it to allocate enough memory for an entire Radio structure. The same is true of your second malloc(), in AppendNewElement(): you are allocating memory for a pointer, not an actual structure.
JR
(5,196 Views)
Ok, i thought  about it too, but this statement occurs the same error:
struct Radio SRadio;  // global
RadioGruppen[GruppenIndex] = malloc(sizeof(SRadio)); // on this line happens too
i do not know, why i can not  allocate memory  this way.
SRadio is the structure in this case, not a pointer, so what a problem ?
(5,190 Views)
