I'm starting from scratch on this. I've looked through the documentation, paper and web site, to find some simple getting started instructions. Found nothing.
I've got an SCXI chassis with four SCXI-1125's, connected to a PCI-6034E. It has been properly set up using MAX, including setting gain and filters on the 1125's.
Using LabWindows 6.0, how do I set this up properly to scan all 32 channels into an array. All of the code samples I've seen are LW 5.5 or older, and do not seem to address, in a straightforward way, the two things necessary: SCXI Module scanning setup, DAQ card reading.
