LabWindows/CVI
Ni 1408 PAL Visibility problem - worked but not anymor
Hi.
I’m want to capture PAL with 1408. At the beginning I was receiving: “cant lock on video source” because I had analogue antenna connected to the card – obviously something was wrong with it, so I connected my cannon camera and it was working just fine, until I restarted the MIX and CVI. Now I get to errors depending on grab option:
<IMG_ERR_TIMO> wait timed out – acquisition not complete” with Snap
and
“ERROR(DMA Timeout) The system is unable to capture all of the incoming data ….”(what makes no sens) with Grab
I had had not changed anything between those moments. Now I was playing with the properties of the card and channel0 in MIX (on which previously I got my pictures) but nothing works. Maybe restore defaults, but I do not know how.
Thanks for replaying.
Pawel
(3,124 Views)
Hi again, well I equipped my self with more cameras like Pulnix.Yes, the MAX is recognizing that it is rs170 but still do not work… here. The program that I recently wrote acutely works. What is the problem for goodness sake? The MAX should not be the program that sets the parameters for the correct functionality of the cams?
(3,067 Views)
