LabWindows/CVI
external compiler support: Intel icl11
Today I have ordered the Intel C Compiler, which by now is version 11. CVI provides templates for icl 8.1, 9 and 10. Does anyone know about possible differences in the setup procedure between 10 and 11? (So far I have never used an external optimizing compiler)
Wolfgang - and happy holidays
(3,752 Views)
Accepted by topic author Wolfgang
Hi Wolfgang,
in general it’s possible, to use the Intel C Compiler Version 11 in CVI.
You have to create your own configuration file.
Use the configuration of the Intel C Compiler Version 10 as template.
Follow these steps:
Choose in CVI: Options -> Build Options -> Compiler for released configuration
Set “New”
Name your configuration e.g. “Intel C++ 11.0”
Create a destination file (*.ecc)
When confirming the dialog, a new pop up will appear named “Compiler for released configuration”
Choose the option “Edit”
Modify the file for the Intel C Compiler Version 11.
Kind regards
Ulrich
AE-NICER
(3,709 Views)
Now that I have installed the Intel compiler I can confirm that it is indeed possible to use it as an external compiler in CVI. One has to manually configure the path, and of course the command line options.
Wolfgang
(3,592 Views)
