LabWindows/CVI
Numeric slide: fill options
In LabVIEW a Numeric Slide has the property "Fill Options" that can be set to
  • Fill to Minimum
  • Fill to Maximum
I haven't been able to find this kind of property for a CVI slide, which always behaves in "Fill to Minimum" mode.
I was able to obtain a behaviour similar to "Fill to Maximum" changing the colors of frame and fill, but this could only be a partial solution...
Is there a way to change the fill mode?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,295 Views)
Accepted by vix
The correct attribute to set in SetCtrlAttribute is ATTR_FILL_OPTION, with possible values VAL_NO_FILL, VAL_TOP_FILL, VAL_BOTTOM_FILL, VAL_RIGHT_FILL, VAL_LEFT_FILL.
(3,292 Views)
