ODBC - Error: Could not load the automation support DLL
I am using CVI 5.5 dev environment, with the 6.0 sql toolkit loaded and using WinXP. The function DBConnect("CONNECTION_STRING") returns "Automation error code -11, Could not load the automation support DLL". My PC is configured correctly, as far as I can tell, with an OpenLink database. Start->Settings->ControlPanel->AdministrationTools->DataSources(ODBC)->System DSN shows that the OpenLink driver is there, and named MFGPRO_database. Its configuration dialog provides a "test Connection" button, that when pressed indicates a successful connection. I believe all I should do to successfully connect is to use the MFGPRO_database as the argument, i.e. stat=DBConnect("MFGPRO_database"). One other note: The only dll I can find (using regedit find) associated with this database name (MFGPRO_database) is c:\programFiles\OpenLink\olod4032.dll. I wondered if copying this dll to the system directory (winnt\system32) would work, it did not, same results.
Anyone have an idea?
(3,896 Views)
Are you still having problems with this?
I've documented this procedure for myself as I always forget how to do it myself.
See my reference page on: http://www.jattie.co.uk/software/cvi/help/sqlstring.htm
Best regards
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,872 Views)
The problem still exists, but I have discovered that the cause is a general incompatibility between the CVI5.5 development environment and the CVI7.1 runtime engine, when using the SQL toolkit. I get a first chance exception fault once for each SQL toolkit library call I make. If I keep hitting the continue button on the error pop-up, it eventually comes out with all of the query information. This behavior only occurs during runtime of a debug executable. Release executables work fine, even if built with the older dev environment on a new runtime engine. Now that I am aware of the incompatibilities, I will just navigate clear.
(3,862 Views)
