I am using CVI 5.5 dev environment, with the 6.0 sql toolkit loaded and using WinXP.  The function DBConnect("CONNECTION_STRING") returns "Automation error code -11, Could not load the automation support DLL".  My PC is configured correctly, as far as I can tell, with an OpenLink database.  Start->Settings->ControlPanel->AdministrationTools->DataSources(ODBC)->System DSN shows that the OpenLink driver is there, and named MFGPRO_database.  Its configuration dialog provides a "test Connection" button, that when pressed indicates a successful connection.  I believe all I should do to successfully connect is to use the MFGPRO_database as the argument, i.e. stat=DBConnect("MFGPRO_database").  One other note:  The only dll I can find (using regedit find) associated with this database name (MFGPRO_database) is c:\programFiles\OpenLink\olod4032.dll.  I wondered if copying this dll to the system directory (winnt\system32) would work, it did not, same results.
Anyone have an idea?
