LabWindows/CVI
ObjIdl.h errors
Hello John,
Thank you for posting. We would be happy to answer your question; however could you please open a new thread when you have a new question.
It would also be helpful for the user community if you mark the solution to your original question on this forum. We tried a number of things, and a user with a similar question would definitely like to be forwarded directly to the correct solution.
Jacob R. | Applications Engineer | National Instruments
Message 21 of 24
(1,437 Views)
OK, I can open a new thread for the new question.
What do you mean by "mark the solution to your original question on this forum" ?
JW
Message 22 of 24
(1,433 Views)
There should be an option somwhere to mark as solved. Either it will be under the Kudos or under the Options on the right.
Message 23 of 24
(1,424 Views)
This would presumably be on the post from me marked with this date: 10-31-2012 04:18 PM
Message 24 of 24
(1,421 Views)
