LabWindows/CVI
Obtain task list from task manager
Hi All,
I have a CVI Labwindow program. I call a web page using InetLaunchDefaultWebBrowser function, when a button is pressed in the UI. I need to suspend the processing of my Labwindow program until web page is closed. I have a question here. How do I get the task list from the task manager ? I want to get the task list and not process list running on the host machine as there may be other instances of web browser running.
Kanu
(3,674 Views)
Hi Kanu,
perhaps this code-snippet will help you ...
regards
Peter
#include <tlhelp32.h>
/// HIFN Get a list of all running processes to check if XXX is running on same system
/// HIPAR szExecutableToCheckIfRunning/char, Name of executable to look for
/// HIRET = 1 found executable to look for
/// HIRET = 0 did not found executable
/// HIRET < 0 error
int GetProcessList(char * szExecutableToCheckIfRunning)
  HANDLE hProcessSnap;
  PROCESSENTRY32 pe32;
  int bFound=FALSE;
  // Take a snapshot of all processes in the system.
  hProcessSnap = CreateToolhelp32Snapshot( TH32CS_SNAPPROCESS, 0 );
  if( hProcessSnap == INVALID_HANDLE_VALUE )
    printf( "CreateToolhelp32Snapshot (of processes)" );
    return -1;
  // Set the size of the structure before using it.
  pe32.dwSize = sizeof( PROCESSENTRY32 );
  // Retrieve information about the first process,
  // and exit if unsuccessful
  if( !Process32First( hProcessSnap, &pe32 ) )
    printf( "Process32First") ; // show cause of failure
    CloseHandle( hProcessSnap );          // clean the snapshot object
    return -1;
  // Now walk the snapshot of processes, and
  // display information about each process in turn
  do
    if (stricmp(pe32.szExeFile, szExecutableToCheckIfRunning)==0)
      bFound=TRUE;
  } while( Process32Next( hProcessSnap, &pe32 ) );
  return bFound;
(3,666 Views)
