LabWindows/CVI
Rotating a Canvas for printing
I currently do an XY scan that draws the measured points to a canvas.   To print the Scan I redraw the XY scan on to a seperate panel and send the print job to the default print or the user has the option to copy the panel as a bitmap.  I need to rotate the graph and axis 90 degrees.  Anyone have a quick way to do that?
(4,809 Views)
This old discussion can help you in developing a routine for rotating the canvas. Both solutionsin that thread start getting the bitmap image of the control with GetCtrlDisplayBitmap, apply the rotation and store the rotated bitmap again into a picture or canvas control.
(4,802 Views)
I'll give it a try
(4,799 Views)
Thanks.  works great.  Now I have to figure out how to reformat the rest.
(4,789 Views)
