LabWindows/CVI
the application uninstaller ,created with Labwindows CVI, doesn´t work after upgrading to 2010 version
I have been working with Labwindows CVI 2009 with no problem but after upgrading to 2010 version I have the following problem:
When i´m going to execute the unistaller, either from Windows Control Panel or directly from the uninst.exe icon, it doesn´t work. The PC thinks a few seconds and does nothing, and it happens with all the applications I build with Labwindows CVi 2010.
Asier
(3,692 Views)
Accepted by topic author asierglez
Hello -
Are you installing these distributions on a non-English operating system?  If so, the first thing to try would be the workaround listed on this known issue
The known issue only lists Italian OSs as the troublesome OS, but it could actually happen on many different non-English OSs. I will update the text accordingly the next time I update the known issues list.
NickB
(3,690 Views)
Does anyone know if all non-English versions of Windows supply the option to switch to English as described in the workaround?
--Ian
(3,685 Views)
Hello NickB,
That´s the solution. I have changed my OS clock to English (EEUU) and it works properly.+
Asier
(3,674 Views)
