LabWindows/CVI
Opening a new window too small
Hi
I have a button on main GUI, when user click this button, a new window pop up but it's pretty small, how to specify the new
window size?
(4,062 Views)
This depends on the type of window... popup panels have a fixed size. If it is a window you have designed you can change your design Smiley Wink This can be done in the UI editor or programmatically using the function SetPanelSize ()
(4,058 Views)
Thanks for the info.
I set the panel heigh/width is what I want it, but panel is in a window which is not big enough, I can stretch it to make it big,
just wondering is there anyway to make it big enough by default?
(4,054 Views)
