LabWindows/CVI
cvi 2013 and win 10
I know that CVI 2013 and Win 10 are not officially compatible, but as I upgraded to Win 10 I'm now using CVI 2013 with Win 10.
At the beginning everything was fine. I could run without any problem my projects.
But when I wanted to build a release version I ran in some troubles. The project builds correctly but then CVI hangs and never displays the uir of the project. I have then to stop CVI and restart it.
I then tried to create a new project just with a button close and I got the same behavior.
Has someone an idea what could be the reason of this issue?
(3,992 Views)
In fact the issue was comming from my antivirus Avast.
After unsinstallation and reinstallation everything is working fine.
(3,968 Views)
