LabWindows/CVI
Out of Bounds pointer arguments (past end of memory
Hello everybody,
I am using Labwindows with Imaqdx 3.1, PXI 1033 and a 1394 camera but when I tried to run the application, the system shows a Fatal Error Message "Out of bounds pointer arguments (past end of memory" with 3 options, Ignore, Break anc Cancel. Using Ignore, you can continue without problems, but I don't want to see that message. The row with the problem is "VisionErrChk(imaqGrayMorphology(image, image, IMAQ_ERODE, &structElem));"
I had been usign Imaqdx 3.0.1 but the original PXI 1033 is not working properly. I changed the old PXI for a new PXI (same model) but the original installations of MAX and Imaqdx were damaged too. For that reason I installed Imaqdx 3.6 and it shows the same fatal error. I don't know if the problem is with the version and I tried uninstalling the 3.6 and deleting the folders. I installed the 3.1 hopping it works, but it didn't. Is the version the reason of the problem?
(3,517 Views)
Hi Dx-Mx,
What is the fatal error you get with IMAQdx 3.6. Have you tried 3.7?
Joe Daily
may the G be with you ....
(3,468 Views)
Hello Joe,
Thanks for your interest in this problem. I have the same problem with the version 3.6, 3.0 and 3.1: Out of Bounds Pointer Arguments.
But, something interestin
@Joe D. wrote:
Hi Dx-Mx,
(3,449 Views)
Hello Joe,
But, something interesting happend when I changed the version to 3.0.1, I received a error when I tried to initialize the camera. But it happend just with this version. Thanks for try to help me.
(3,448 Views)
Hi DX-MX
Try upgrading to imaqdx 3.7 and seeif that fixes anything. Also after upgrading run the NI camera valiadator here
Joe Daily
(3,418 Views)
