LabWindows/CVI
Use DO and AI function in one DAQ Device
Hi, everyone
I try to use DO and AI function in DAQ USB-6008.
When I run my program it shows one error message as below,
Please suggest me how to solve this problem?
Thank you!
My Code:
DAQmxCreateTask("", &gTaskHandle_DAQ1);
DAQmxCreateTask("", &gTaskHandle_DAQ1_DO);
DAQmxCreateAIVoltageChan(gTaskHandle_DAQ1, cChan_DAQ1, "", DAQmx_Val_Cfg_Default, min,max, DAQmx_Val_Volts, NULL);
DAQmxCfgSampClkTiming(gTaskHandle_DAQ1, "", rate, DAQmx_Val_Rising, DAQmx_Val_ContSamps, sampsPerChan);
DAQmxGetTaskAttribute(gTaskHandle_DAQ1, DAQmx_Task_NumChans, &gNumChannels);
DAQmxCreateDOChan(gTaskHandle_DAQ1_DO, cChan_DAQ1_DO, "", DAQmx_Val_ChanForAllLines);  <--- Occur error
(3,840 Views)
Can you provide more info. such as
ni-daqmx version? or ni-daqmx base version?
OS?
Visual C++ version? Borland C++ version?
(3,806 Views)
hi, Billingsley
My DAQ version is 7.4.4f4
      OS version is  XP Profession SP3
      LabWindows/CVI version is 8.5.0
Thank you!
(3,797 Views)
Sorry, add below.
(3,796 Views)
Can you try all AI & DO functions on Measurement and Automation Explorer>>Test Panel?
or Can you update your NI-DAQmx driver to 8.6.1?
or may be you need to RMA.
(3,790 Views)
