LabWindows/CVI
PID toolkit won't install with CVI 6.0 on Win2K/NTFS volume
Anybody have any idea why the LabWindows/CVI PID toolkit won't install on my Win2K Pro SP3 system? Using PID toolkit P/N 776991-01 Version 1.1 and setup floppy disk for Win32 (P/N 500449A-00)
Setup program says insufficient disk space - that I need at least "0 bytes available".
File system is NTFS and the volume has 60GB free.
After spending $300 for the toolkit, I was kinda hoping it would at least install OK 😉
Message 1 of 9
(4,354 Views)
The PID toolkit installer was written with old technology. It has a bug in that it can not handle over 4GB of free space without starting to read negative. This seems to only occur on WinNT and Win2K. I get it to work on WinXP just fine.
If you would give me your personal email address I will send you the files it installs and how to install them properly.
Jeff
NI
Message 2 of 9
(4,354 Views)
Thanks Jeff, I kindof thought that this might be the case due to the "zero bytes needed" error message.
I can be reached at
hayes@raytheon.com
Message 3 of 9
(4,352 Views)
Jeff-
I installed the toolkit onto an NT system and then simply copied the files over onto the Win2K system. Everything appears to be working.
Thanks for your help - too bad this isn't mentioned in the readme file, it would have saved me (and others I imagine) a lot of hassle.
Message 4 of 9
(4,352 Views)
Hi Jeff ,
I also encounter the same problem , could you please give an advise ? Thanks.
David (Davidlee62@yeah.net)
Message 5 of 9
(4,325 Views)
It is an issue with the PID toolkit installer. There is nothing I can tell you other that to try and find a computer with a disk smaller than 4GB. Then copy the files over. If this is not an option, I can zip the files and send them to you.
Please provide me with:
Name
Company
Product
Serial#
Jeff
Message 6 of 9
(4,319 Views)
Hi Jeff,
It just a package in the Developer suite. the developer suite serial No. is Z12G02560 .the PID toolkit P/N is 321062A-01 .
Company name : Sunten electric Co. China.
David
Message 7 of 9
(4,311 Views)
David,
I need your email address. It does not show up in your Member profile.
Jeff
NI
Message 8 of 9
(4,288 Views)
Hi Jeff,
Thank you for being enthusiastic , I have solved the problem .
David
Message 9 of 9
(4,278 Views)
