LabWindows/CVI
Set the label length of Tab ctrl
Hello ,
Using easytab package can generate a tab ctrol easyly , but the label (title) length just changed follows the label text length , e.g, if set 2 characters , it just shows the tab handle as a short modes. I need to set a fixed label length , is there a method ?
David
(2,993 Views)
Apart from creating a tab title with extra spaces added, you can only impose that the tab expand to occupy all of the tab control width by using
EasyTab_SetAttribute (panel, control, ATTR_EASY_TAB_STRETCH_TO_FIT, 1);
(2,987 Views)
