LabWindows/CVI
PXI Trigger functionality / MUX<->DMM Handshaking
Hello everyone,
currently I’m working on an old Labwindows/CVI project and I’m getting timeouts while using internal PXI trigger functionality.
Old HW:
Teststand 3.5
PXI-1045
DMM PXI-4070
MUX PXI-2530
New HW:
CVI2020 / IVI 2020/ Teststand 2021
PXIe-1084
DMM PXI-4080
MUX PXI-2530B
This code worked on old hardware, however on new hardware there seem to be problems with handshaking functionality:
Scanlist = “ch0->com1;ch1->com0;”;
device = 1;
  checkErr(niSwitch_init(MUXdevice, VI_TRUE, VI_TRUE, &MUXsession));
  checkErr(niSwitch_ConfigureScanTrigger(MUXsession, 0.0, NISWITCH_VAL_TTL0, NISWITCH_VAL_TTL1));
  checkErr(niSwitch_ConfigureScanList(MUXsession, ScanList, NISWITCH_VAL_BREAK_BEFORE_MAKE));
  device = 2;
  checkErr(niDMM_init(DMMdevice, VI_TRUE, VI_FALSE, &DMMsession));
  checkErr(niDMM_ConfigureMeasurementDigits(DMMsession, NIDMM_VAL_DC_VOLTS, Range, Digits));
  checkErr(niDMM_ConfigureMultiPoint(DMMsession, nroutes, 1, NIDMM_VAL_TTL1, -1));
  checkErr(niDMM_ConfigureMeasCompleteDest(DMMsession, NIDMM_VAL_TTL0));
    device = 1;
    checkErr(niSwitch_InitiateScan(MUXsession));
    // set DMM into armed state (DMM triggers scanning per default)...
    device = 2;
    checkErr(niDMM_Initiate(DMMsession));
    // wait for scan list to be processed once...
    device = 1;
    checkErr(niSwitch_WaitForScanComplete(MUXsession, Timeout_ms));
    // now get measurements (no measurement, just fetching)...
    device = 2;
    checkErr(niDMM_FetchMultiPoint(DMMsession, Timeout_ms, nroutes, reading, &points));
When executing the code above I get the error -1074126826 Max Time Exceed (->WaitforScanComplete Timeout).
Any ideas?
(1,125 Views)
VI devices can be notoriously difficult to configure in NI-MAX. Are you sure their setups are good ? You should make little test programs for each of them and test them.
Also I wonder about all your device=... lines. Is there more than meet the eyes in your code ?
(1,089 Views)
