Parse Iak-File with CVI
Hi, I need to get a similiar function like "FP Get Configuration Info.vi" within CVI. Any suggestions? Peter
(3,446 Views)
Hi Peter,
I took a look at the VI and found the DLL.
Perhaps you can use this dll.
Perhaps this helps.
(3,427 Views)
and here is the dll...
and the prototype:
uint32_t ialv_configuration_info(const CStr path, uint8_t operation, const CStr server, const CStr resource, const CStr device, Array2DUint8_t **info, LStrHandle source);
Hope this helps....CVi don't have a funtction like this
Best regards
Dippi
(3,426 Views)
Hi, thx for the answer. I know of these function, but within LabVIEW, it will get a parameter "Server", which comes from an "authorization function" FindProjectName. Can I leave this parameter empty? Another point, can I use this function without an installed LV runtime? Thx again for your help! Peter
(3,398 Views)
