Parse text and identify which column(s) contain non-matching data
Hi everyone,
I want to write an elegant solution in LabWindows-CVI to accomplish the same as what I implemented in LabVIEW.
The client does not use or own LabVIEW.  I must code the solution in CVI.
In order to simpify the explanation of what it is that I attempt to do, I wrote a quick example in LabVIEW (see below):
The code needs to parse a string to identify which column of data has non-matching elements.  In order to do so, I first removed the unwanted text at the top and bottom.  I also removed the additional space between the 2 groups of data by replacing the two spaced with a single one to make the next step easier.  The resulting string was converted to a 2D array of string.  Only the desired columns to be searched were kept (total of 16 columns).  The 2D array was transposed because the search 1D array searched each row, whereas I want to search each column.  The entire transposed 2D array was searched for any non-matching values, which populates a 1D array of boolean.  I converted the 1D array of boolean to a number to see if any "non-matching data" was found.  If none were found, then the value would be zero.
I need help coding this into CVI.
Many thanks,
RayR
Message Edited by Ray.R on 10-04-2009 09:47 PM
Message 1 of 8
(4,893 Views)
Accepted by Ray.R
Ray, string aspect makes me think it is a memory dump, so I designed a solution that scans integer values from the string and operates on them, instead of working on the string itself. Take a look at the attached sample that should be what you are looking for; feel free to add comments or ask clarifications on some instruction if you need them.
Message 2 of 8
(4,880 Views)
Many thanks Roberto,
Your code example certainly meets the "Beautiful Code" criteria. 🙂
It's a very elegant approach, which would even make LabVIEW blush.  😉
Best Regards,
RayR
Message 3 of 8
(4,870 Views)
I need a bit more help.
The data in my case is not from a file, but rather passed by a pointer from the calling function (pcTestData)
I tried to use tokens to seperate each line and use it withinthe code you provided, but I keep running into some strange problem.... it doesn't work..  😞
Here's the portion of code which fills up int d[16][16]
    str1 = strtok(pcTestData, "\n");
    /* loop until finishied */
    while (!done)
        /* extract string from string sequence */
        str1 = strtok(NULL, "\n");
         if (FindPattern (str1, 0, 10, "48", 0, 0) >= 0)
            Scan (str1, "%s[dxt32]%16x[x]", d[i++]);
        /* check if there is nothing else to extract */
        if (str1 == NULL)
            MessagePopup ("> Tokens <", "Token are complete");
            done = TRUE;
        x++;
Below is the actual data:
d 48000000 100
48000000: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
48000010: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
48000020: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
48000030: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
48000040: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
48000050: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
48000060: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
48000070: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
48000080: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
48000090: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
480000A0: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
480000B0: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
480000C0: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
480000D0: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
480000E0: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
480000F0: A5 A5 A5 FF A5 A5 A5 A5  A5 A5 A5 FF A5 A5 A5 A5   ................
40000000*
Message 4 of 8
(4,829 Views)
Oh.. and yes, I did change the 0xAA to 0xA5 in the rest of the code (actually, it became a parameter)  😉
Message 5 of 8
(4,828 Views)
I cannot test here, but I can see problems with the "48" appearing in the first row: it will be detected even if not at the beginning of the row since you are searching into the first 10 characters of the string; on the other hand, it appears that you are skipping the first token (line) since in the loop you immediately select another token. I would organize the code this way:
    str1 = strtok (pcTestData, "\n");
    i = 0;
     /* loop until finished */
    while (str1)
         if (FindPattern (str1, 0, 3, "48", 0, 0) >= 0)
        /* find if there are more tokens */
        str1 = strtok (NULL, "\n");
    // No more tokens to scan
Message 6 of 8
(4,820 Views)
Roberto beat me to it, but for what it's worth, here's my version:
for (str1 = strtok (pcTestData, "\n"); str1; str1 = strtok (NULL, "\n"))
    if (FindPattern (str1, 8, 1, ":", 0, 0) >= 0)
        Scan (str1, "%s[dt32]%16x[x]", d[i++]);
NickB
Message 7 of 8
(4,806 Views)
Many thanks guys.
Message 8 of 8
(4,795 Views)
