LabWindows/CVI
Partial linux install
Hello all,
OK, I installed the LabView CD on Linux, but I'm only interested in the CVI
parts.
I have a \usr\local\natinst\cvirte directory but no \usr\local\natinst\cvi80
and thus no cvicc...
Did I miss something on the installation CD ?
Guillaume Dargaud
http://www.gdargaud.net/
Message 1 of 8
(5,024 Views)
Hi Guillaume,
The Linux installation should place files in these directories:
  • \usr\local\natinst\cvi80
  • \usr\local\lib
What installation CD were you using to install CVI for Linux? Per this link you should just need to run the INSTALL script and it will install the correct directories.
Test Engineer - CTA
Message 2 of 8
(4,994 Views)
> Hi Guillaume, The Linux installation should place files in these
> directories:
> - \usr\local\natinst\cvi80
> - \usr\local\lib
CD is labeled "Professional Development System fo Linux", Fall2006, Version
8.2, 501448A-113
> Per <a href="http://zone.ni.com/devzone/cda/tut/p/id/2823"
> target="_blank">this</a> link you should just need to run the INSTALL
> script and it
The script installed mostly LabView related stuff, with the addition of the
CVI runtime engine and VISA stuff.
Guillaume Dargaud
Message 3 of 8
(4,986 Views)
Guillaume,
That installation CD is the LabVIEW Professional Development System for Linux, not the CVI Run-Time Module for Linux. You will need to find the LabWindows/CVI Run-Time Module for Linux installation CD.
Test Engineer - CTA
Message 4 of 8
(4,964 Views)
Arghhhh... always something missing !
Is this runtime supposed to be part of the NI CD/DVD kit or is it a separate
purchase ?
And how come I have \usr\local\natinst\cvirte ? If it something that came
out after my fall 2006 DVD release ?
The Extended Development Suite DVD has a bunch of linux directories, but
they seem unrelated. The Linux CD contains only nicvirte-8.0-5.i386.rpm as
CVI related.
Message 5 of 8
(4,948 Views)
LabVIEW is dependant on the CVI RTE so that is why you are seeing the nicvirte on the LabVIEW installation. The CVI Run-Time Module for Linux does not come with devsuite. You will need to contact NI Sales to get a copy.
Test Engineer - CTA
Message 6 of 8
(4,928 Views)
> nicvirte on
> with
Talking with them right now...
I assume that in order to create a Linux executable, you _need_ cvicc. Or
maybe you can cross-compile from Windows like you do for the real-time OS ?
I somehow doubt this as I haven't seen any info on the subject.
I'd like to see some examples of Linux CVI programs...
Guillaume Dargaud
Message 7 of 8
(4,888 Views)
Hi back Guillaume,
Thanks for having taken contact with me in France. Please check your email regarding the cvicc that is missing to you.
Regarding your last question, it is answered here, in the FAQ part more specifically in the Q: How do I build and run my LabWindows/CVI project? section.
I hope this can help you. Don't hesitate to ask for more.
Message Edité par Mathieu Steiner le 04-23-2007 09:09 AM
Message 8 of 8
(4,883 Views)
