Pass parameters custom popup
Hello.
I created a panel and want to show it like popup modal dialog.
My code is:
int panelHandle = LoadPanel(0, "Dialog.uir", PANEL);
if(panelHandle < 0)
return 0;
DisplayPanel(panelHandle);
RunUserInterface();
DiscardPanel(panelHandle);
I need to pass several parameters into the dialog. How can I do it?
Thank you.
(5,031 Views)
First of al, DisplayPanel does not show a panel as modal: use InstallPopup instead.
How are intending to customize the window?  Can you add some details?
(5,019 Views)
Hi Roberto, thank you for your answer.
There are  couple spinboxes and on dropdownlist on the popup (or panel), "OK" and "Cancel" buttons. So I want to pass couple double values and pointer to char (char*) to the dialog.
(4,991 Views)
Accepted by giker
Could a series of SetCtrlVal do what you want?
(4,987 Views)
Yes. It works. Thank you.
(4,984 Views)
You're welcome.
It looks like you are quite new to CVI: you should seriously consider reading the Getting Started manual; you'll find it linked in <cviDir>\bin folder, where <cviDir> is CVI installation folder.
(4,978 Views)
