LabWindows/CVI
Passing 2D Array of char (1D string) out of a function
I have made a function to get list of name in array but i don t to get it out of the function.
See under:
In the main program :
int iAdjustTableRows()
char **szArrayRes;
GetDataFromDB_OneCol  ("Group_Instrument","Group_Name",szArrayRes)
Im not abble to retrieve my array of string szArrayRes !!! Why ??
return 0;
Function
int GetDataFromDB_OneCol ( char *szTableName, char *szColuName,char **szArrayResults)
 char szValue [50]=""; char szQuery [512]="";
 int  resCode,  iValueStatus =0,numLine=0;
    int  hmap =0,  i=0,u=0;
    int  hstmt;
 //*** Get number of line (record)
   // Formating of query
   sprintf(szQuery, "SELECT %s FROM %s ",szColuName,szTableName);
   // Select statement
   hstmt = DBActivateSQL (hdbc, szQuery);
   if (hstmt<= DB_SUCCESS) {ShowError(); goto Error;}
   // Get Number of Column
   numLine =  DBNumberOfRecords (hstmt);
   resCode = DBDeactivateSQL (hstmt);
   if (resCode != DB_SUCCESS) {ShowError(); goto Error;}
  //*** Dimension of 2D array of char accrding to number of line
   szArrayResults = malloc(sizeof(char*)*numLine);
   //memory allocaring for array
   for(u = 0; u <  numLine; ++u)
     szArrayResults[u] = malloc(sizeof(char)*300);
     Fmt(szArrayResults[u],"");
  //*** Begin map for constructed SQL statement */
      hmap = DBBeginMap (hdbc);
      if (hmap <= 0) {ShowError(); goto Error;}
         // Specify the columns to be selected and the variables where column values will be placed. //
                    resCode = DBMapColumnToChar (hmap , szColuName, 50, &szValue, &iValueStatus, "");
           hstmt = DBActivateMap (hmap, szTableName);
                 if (hstmt <= 0) {ShowError(); goto Error;}
   //*** Fetch Data until end and fill out array of string
          while (DBFetchNext (hstmt) == 0) {
              if (iValueStatus != DB_NULL_DATA){
                    Fmt(szArrayResults[i],"%s",szValue);
                    i++;
At this point the table of string is fill out correctly .
   //*** Free Mapping SQL
   resCode = DBDeactivateMap(hmap);hmap =0;
 //*** Error handling
 Error:
   if (hmap)
   hstmt = 0;
 return 0;
(4,492 Views)
try
char **szArrayRes;
GetDataFromDB_OneCol  ("Group_Instrument","Group_Name", &szArrayRes)
You might want to return a value with the number of strings
Curt
(4,456 Views)
