LabWindows/CVI
Progress Bar Control goes not Responding
I am using a progress bar control in my application.
there are several other UIR in the application as well.
i embed all the UIR while creating the executable.
the progress bar control works good if i run from the development environment without any issue.
once i build the application and create a exe and run , the progress bar goes (Not Repaonding) even if there is a small mouse click in the screen.
but it works OK if i leave the system untouched without any activities.
what could be the issue?
any help is appreciated!!!
Thanks in advance
Bharathi
(4,972 Views)
Hello, IVI!
Please let us know the version of LabWindows/CVI and CVI Run-Time that you are using!
Also, providing more context (e.g. some code, or even a project) would also help.
Best regards!
- Johannes
(4,963 Views)
am using labwindows 2010 runtime and engine.
i am updating the progress bar percentage as 5.5% each in  a 18loop ,
in intialize the follwing code is use:
"Gma_prg_panelHandle = LoadPanel (0, "Gamma_percentage.uir", PANEL);
ProgressBar_ConvertFromSlide (Gma_prg_panelHandle, PANEL_PROGRESS);
ProgressBar_SetAttribute (Gma_prg_panelHandle, PANEL_PROGRESS,ATTR_PROGRESSBAR_UPDATE_MODE, VAL_PROGRESSBAR_AUTO_MODE);"
in Loop :
for(data_point=1;data_point<=max_gamma_pts;data_point++)
/*Incremnt the Progress Bar for each Sample Point*/
gamma_per=gamma_per+5.55;
SetCtrlAttribute(Gma_prg_panelHandle,PANEL_PROGRESS,ATTR_VISIBLE ,0);
SetCtrlAttribute(Gma_prg_panelHandle,PANEL_PROGRESS,ATTR_VISIBLE ,1);
sprintf(buffer,"Working on GAMMA measurement... (Processing sample point %d of 18)",gamma_count);
ProgressBar_SetPercentage (Gma_prg_panelHandle,PANEL_PROGRESS , gamma_per,buffer);
/*other stuff*/
Bharathi
(4,953 Views)
