LabWindows/CVI
Photon Focus MV-D1024E-160-CL-12 Camera frame rate problem.
I have checked the frame rate in MAX and I can get the camera to run maximum at 70 fps when I am triggering externally. However when I am triggering internally I can get it to run maximum at 150 fps.
Farhan Ahmad.
Message 11 of 15
(1,775 Views)
Andy,
Do you have the CalculateFPS.vi available for v8.6?
-Graham
@Andy C. wrote:
Hello Farhan,
You can use the Calculate FPS VI here to display the number of frames/second for your camera.
Message 12 of 15
(1,731 Views)
You should be able to find this VI in the Low-level Grab.vi found in the example finder.
In the example finder, go to Hardware Input and Output--> IMAQdx--> Low Level --> Low Level Grab.vi
Tejinder Gill
Applications Engineer
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
Message 13 of 15
(1,712 Views)
I found it, it's slightly renamed and hiding in Vision>Drivers>Express somethingorother.
Thanks!
Message 14 of 15
(1,710 Views)
CalculateFPS.vi is no longer available in the examples in the new IMAQ directory.
LabVIEW 2016\examples\Vision Acquisition\NI-IMAQdx\High Level\SubVIs
Thank you for posting the VI.  I copied it into my older example code and it works.
Message 15 of 15
(1,003 Views)
