LabWindows/CVI
Picture ring animation freezes (LabWindows)
Hi all,
I want to display a wait panel with an animation in it when my app is processing data, using the animation control. The problem is that the animation freezes because all the resources are in the data processing (when it's no data processing, the animation works correctly).
I tried to create a thread for running the wait panel on it, but it continues freezing because there's a loop waiting for when data processing is finished. I created another thread for that loop, and now the animation works, but only if there's events over the waiting panel (moving the mouse over it or something).
I know this is not very efficient. Maybe someone knows an easy way to do this.
Thank you!!
My code is this:
int Calculate (...)
        ShowWaitPanel();
       //DATA PROCESSING...
        HideWaitPanel();
void ShowWaitPanel(void)
    waitPanelActive=1;
    CmtScheduleThreadPoolFunction (DEFAULT_THREAD_POOL_HANDLE,WaitThreadFunction,
        NULL,&waitThreadFunctionId);
void HideWaitPanel(void)
     waitPanelActive=0;
    CmtWaitForThreadPoolFunctionCompletion (DEFAULT_THREAD_POOL_HANDLE,
                 waitThreadFunctionId,OPT_TP_PROCESS_EVENTS_WHILE_WAITING);
    CmtReleaseThreadPoolFunctionID (DEFAULT_THREAD_POOL_HANDLE, waitThreadFunctionId);
static int CVICALLBACK WaitThreadFunction (void *functionData)
    waitPanelHandle = LoadPanel (0, "SpectrumAnalyzer.uir", WAITPANEL);
     DisplayPanel (waitPanelHandle);
    AnimateCtrl_ConvertFromPictRing (waitPanelHandle,  WAITPANEL_PICTURERING);
    AnimateCtrl_SetAttribute (waitPanelHandle, WAITPANEL_PICTURERING, ATTR_ANIMATE_ENABLED, 1);
    AnimateCtrl_SetAttribute (waitPanelHandle, WAITPANEL_PICTURERING, ATTR_ANIMATE_FRAME_INTERVAL, 0.1);
    AnimateCtrl_SetAttribute (waitPanelHandle, WAITPANEL_PICTURERING, ATTR_ANIMATE_STOP_ON_LAST_FRAME, 0);
    CmtScheduleThreadPoolFunction (DEFAULT_THREAD_POOL_HANDLE,CheckWaitPanelFlagThread,NULL,&checkWaitFlagThreadId);
    CmtWaitForThreadPoolFunctionCompletion (DEFAULT_THREAD_POOL_HANDLE,checkWaitFlagThreadId,
    CmtReleaseThreadPoolFunctionID (DEFAULT_THREAD_POOL_HANDLE, checkWaitFlagThreadId);
    DiscardPanel (waitPanelHandle);
    return 0;
static int CVICALLBACK CheckWaitPanelFlagThread (void *functionData)
    while(waitPanelActive)
    return 0;
(3,994 Views)
Any suggestions?
(3,949 Views)
Accepted by Tamargo
You need to process events. The second scheduled thread function is not necessary. Try this:
        ProcessSystemEvents();
    return 0;
Mert A.
(3,945 Views)
It works perfectly.
Thank you very much!!
Eduardo - Spain
(3,943 Views)
