Please explain CVI Issue #335358: Using the bit shift operator twice on the same line of code produces incorrect results
I just stumbled across https://www.ni.com/en/support/documentation/bugs/10/archived--labwindows--cvi--2010-and-2010-sp1-kno...
Using the bit shift operator twice on the same line of code produces incorrect results.
Workaround: Separate the two bit shift operations into two separate lines of code.
Reported Version: 9.0    Resolved Version: N/A    Added: 02/14/2012
Could someone please explain what kind of construct causes such an issue?
I haven't noticed any problems yet and haven't noticed or found a thread about this.
Thanks.
/* Nothing past this point should fail if the code is working as intended */
(4,776 Views)
Does have anyone any information?
From quick search I found over 150 lines with multiple bit shift operators on one line in our source codes, and some of this is in macro definition.
Lot of this code has been developed originaly with CVI7.1 and near 30% of this has been recompiled by CVI2010.
I do not see any problem yet.
(4,758 Views)
Accepted by CVI-User
The reported scenario looks like this:
unsigned int a = 1, b = 62;
unsigned  long long result = 1ULL << a << b;
The problem occurrs because of the temporary variable used when doing two bit shifts in the same line. Separating this into two lines will produce the correct results:
unsigned  long long result = 1ULL << a;
result = result << b;
(4,743 Views)
Thank you D Biel,
               According to your message and some of my quick tests, it seems to me ,that the problem occur when shift operator is inside another shift operator(on left side) and value is 64bit number.
               However, code like (1ULL << a) +(1ULL<< b) works well, which cover most of my ussage cases (of shift operator). I have similar code on only 3 places,but not with 64bit number so it is fine.
               It would be nice if you can change text in known issue list with better description and/or add example so there be less panic for any reader.
(4,728 Views)
Thanks.
(4,720 Views)
