LabWindows/CVI
Please inform for LabWindows/CVI certification exam
What Exam Duration, Style of exam and Passing grade have LabWindows/CVI certification exam
Best regards
Artyom
(4,712 Views)
The only certification available at present on CVI is CCVID: Certificate CVI Developer.
The exam is normally a 4-hour time in which you have to answer a questionnaire and write a little application base on specifications you receive in the exam day. Questionnaire will mainly cover part of the Programmer Reference Guide.
With reference to coding, you are required to write the app complete with technical documentation; you may be required also to write a small user guide for the application. The development will not imply any additional library or toolkit other than CVI core (no DAQ, no VISA, no communications...).
Questionaire and code are assessed independently and the final result is the sum of both.
That is: you must be fast! Smiley Wink It will help if you acquired in your activity a consistent coding style, since this will be evident in the code you develop.
(4,708 Views)
Thank you, and how is Passing grade?
(4,702 Views)
I seem to remember that you must be over 80%, but while it is easy to detect correct answers to questionnnaire, evaluating code style and quality is not as simple.
Nevertheless, 80% is a high level goal.
(4,696 Views)
Thank you
(4,693 Views)
I believe the old CCVID had a programming section, although the test has since changed and is currently just a one hour multiple choice exam.  Your best resource will be this link:
https://education.ni.com/badges/resources/1258
Michael Keane
(4,668 Views)
