LabWindows/CVI
How can I make a session back to local?
Hello
How can I bring my equipment opened with a session back to local mode?
For devices I opened with ibdev, I can use
int ibloc (int Device);
But for equipments opened with viOpen () or rsfsq_init (,,, &session)  ?
Matthias
Message 1 of 8
(4,710 Views)
Try:
viGpibControlREN("Instrument Handle", VI_GPIB_REN_DEASSERT);
-Regards
John O'C
Staff Test Systems Engineer
Woodward, Inc.
Skokie, Illinois, USA
"Life is not a journey to the grave with the intention of arriving safely
in a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, and loudly proclaiming...
Wow...What a Ride!"
Message 2 of 8
(4,667 Views)
Hi Again,
There is also a function to send GPIB commands when in a VISA session.
viGpibCommand("instr handle", Buffer var, count var, ret_count var);
Where Buffer var contains the GPIB command string such as ibloc or Ibconf.
Regards-
OC
John O'C
Woodward, Inc.
Wow...What a Ride!"
Message 3 of 8
(4,668 Views)
I do not think you can send ibloc or ibconf as command strings to the device.
These are functions from a library.
The viGpibCommand function is probably used like this: viGpibCommand (handle, "*RST", 4, &count)
S. Eren BALCI
IMESTEK
Message 4 of 8
(4,644 Views)
Hello
I tried viGpibControlREN("Instrument Handle", VI_GPIB_REN_DEASSERT);
Surprisingly it was setting all equipment to local, not only the addressed one. Also using a next GPIB command left the equipment in local mode.
I guess that is not normal behavior. Right?
Message 5 of 8
(4,581 Views)
Matthias,
When you used the command "viGpibControlREN("Instrument Handle", VI_GPIB_REN_DEASSERT);", is your Handle assigned to the GPIB address of a particular instrument or or to the gpib card itself like 'GPIB0' or 'DEV0'?
John O'C
Woodward, Inc.
Wow...What a Ride!"
Message 6 of 8
(4,567 Views)
Matthias,
To Clarify, what is your instrument descriptor when you do the viOpen() for the instrument that you are trying to toggle from remote to local?
John O'C
Woodward, Inc.
Wow...What a Ride!"
Message 7 of 8
(4,562 Views)
Just for anyone else that comes across this;  the parameter VI_GPIB_REN_DEASSERT, de-asserts remote-enable on all instruments on the GPIB.  For a specific instrument, use VI_GPIB_REN_ADDRESS_GTL.  This is integer number 6.
Message 8 of 8
(3,780 Views)
