LabWindows/CVI
interfacing FPGA C API
Interfacing with FPGA using LabWindows / other applications. Which is better?:
I need to interface with FPGA through the code generated based on LABVIEW. Is it a better way to use LABWindows to access or other framework?
Which makes the design easier and efficient ?
What are the advantages of using LABWIndows over other framework?
Which is the commom method used across to do the same. Please suggest with your ideas.
Message 1 of 1
(4,092 Views)
