LabWindows/CVI
PlotBitmap rises CPU
I use the PlotBitpmap function and I considered the hints I read in this forum:
- disabling the  ATTR_REFRESH_GRAPH before calling PlotBitmap
- setting the width and height to 0.0  like PlotBitmap(handle, PANEL_GRAPH, x, y, 0.0, 0.0, NULL);
- discarding the Bitmap after plotting
With small bitmaps everthing works fine. But I want to plot a semi transparent bitmap created with NewBitmapEx() which height is about 870px. With some graphic cards (like the ATI Radeon 9250) the Plotbitmap function causes a percent rise of the CPU about 40% an my application hangs up.With other graphic cards I have no problems too.
What may cause this problem?
Thanks in advance
(4,339 Views)
Hello Inomed1,
which version of CVI do you use?
Maybe the problem comes from the graphicscard-driver. So please download the newest driver and test it again.
If this doesn't solve the problem please send a small example.
Thank you.
With best regards,
Ralf N.
Application Engineering
Germany
(4,323 Views)
Hello Ralf N.
thanks for your reply.
- I use the LabWindows CVI 8.5.1
- I installed the newest driver of my graphic card, but I have the same problem, too.
Here is my example code:
static void PlotAlphaBitmap (int windowHandle, int *plotHandle, double x, double y, int width, int height, int colorDepth)
int size;
int bmpId;
int bitmap;
unsigned char *pixels;
unsigned char *mask;
unsigned char *alpha;
SetCtrlAttribute (windowHandle, PANEL_GRAPH, ATTR_REFRESH_GRAPH, 0);
if (*plotHandle > 0)
SetCtrlBitmap(windowHandle, PANEL_GRAPH, *plotHandle, 0);
DeleteGraphPlot(windowHandle, PANEL_GRAPH, *plotHandle, VAL_DELAYED_DRAW);
*plotHandle = -1;
size = sizeof(unsigned char) * width * height * colorDepth;
pixels = (unsigned char*) malloc(size);
mask = (unsigned char*) malloc(size);
alpha = (unsigned char*) malloc(size);
memset(pixels, 0xff, size);
memset(mask, 0xff, size);
memset(alpha, 0x40, size);
bitmap = NewBitmapEx(-1, colorDepth, width, height, NULL, pixels, mask, alpha, &bmpId);
*plotHandle = PlotBitmap(windowHandle, PANEL_GRAPH, x, y, 0.0, 0.0, NULL);
if (bitmap >= 0 && *plotHandle > 0)
SetCtrlBitmap(windowHandle, PANEL_GRAPH, *plotHandle, bmpId);
SetCtrlAttribute (windowHandle, PANEL_GRAPH, ATTR_REFRESH_GRAPH, 1);
DiscardBitmap(bmpId);
free(pixels);
free(mask);
free(alpha);
 With best regards
(4,304 Views)
Hello Inomed1,
thanks for the reply.
At first glance it's not a obvious problem...
So it would be the best if you send me a simplified CVI-project (with all necessary files) so that we can reproduce the issue here.
Does it hang the first time when you call the PlotAlphaBitmap()-function or after serveral calls?
With which graphic-cards did you test the project?
Till the next time.
With best regards
Ralf N.
Applications Engineering
(4,285 Views)
