LabWindows/CVI
SCAN_to_Disk
    I am using SCAN_to_Disk() function available which stores the conversion result in the file specified in the function argument. I am facing  a problem here. The gain setting is configured for 0.5, so i can apply input voltage upto 10V to ADC channel and read the conversion. But the problem is i am able to read only upto 8.9V. If input voltage touches 9 volts or higher, the output file shows junk characters. I have attached the .c file, kindly let me know if there is any problem with the way i have configured the ADC.
Is there any way by which SCAN_to_Disk() function saves the conversion results in a "Microsoft Excel Worksheet.xls" file. Kindly let me know if by any means we can store the conversion results obtained using SCAN_to_Disk() function in a known file format (.xls, .doc or .txt)
Rakesh
Message 1 of 1
(2,925 Views)
