PlotStripChart with continuous sampling DAQmx and multiple channels
I have modified the DAQmx sample code sychAI-AO.cws slightly to offer more output wavforms. I can read simultaneously on one channel no problem. Then when I try two channels I read in an array of N (N>>2, a lot of PlotStripChart examples have N=2 with 2 traces so it updates one point at a time... I don't want that.)  samples. 0 to N/2-1 is what AO1 (output channel 1) writes out, and N/2 to N-1 is what AO2 writes out. Now if I set the number of traces to 2 and try to plot them on a stripchart I get the entire array 0 to N-1 on both traces.
How do I plot an array of say 10000 samples on 2 traces with the array grouped by channel?
Thank you
(5,433 Views)
Accepted by EricJR
I changed my DAQmxReadF64 to Group by Scan Number instead of by channel and set skipcount = 0 and staringIndex = 0 and that worked exactly the way I wanted it to... but according to documentation it should not work.
(5,424 Views)
Why you say it shouldn'work? It seem the exact way it should to me.
(5,394 Views)
You are right RobertoBozzolo. I guess I was initially confused by the documentation of skipcount and startingindex, but I got some clarifcation from an answer on the labwindows forum. Possibly a post by you 🙂 I just don't understand how groupbychannel didn't work. What should skipcount and startingindex be if I have an array of 1000 elements and the first 500 elements are my first trace and the last 500 are my second trace?
Thanks again.
(5,383 Views)
You can't organize your data this way, that's how stripcharts work. You can plot a single point per trace by passing an array with one element per trace. Passing a larger array simply permits to plot more points per trace, but the intreleaved structure is to be respected anyway.
(5,374 Views)
