LabWindows/CVI
PlotXY invisible with VAL_THIN_LINE
I'm trying graph a plot using PlotXY, but the graph is not showing up if the plot style parameter is VAL_THIN_LINE. If I use VAL_THICK_LINE, the plot does appear. I tried changing the resolution of the graph, but it didn't help any. Has anyone else had this problem?
(2,973 Views)
Hello. I tried a small example program on my machine, and the thin line appears to be working well. Maybe you could post up a small clip of code that replicates the issue, or give a little more description of what you are trying to plot so we can look into it, and see if we can find you a resolution.
Thanks.
Daniel McChane
Application Engineer
(2,973 Views)
