LabWindows/CVI
a simple application
i would want to make a application that does only some handles maths with arguments passed to the function more os less is the following:x=(y*z)/k where this parameters would be entered o the user interface and with the button run o results will appear on the screen?What is the steps should i do to perform that?
**I send in attachment a file with the user interface that i intend to use, as i am a beggining in the matter i would like that you pas to me how can i must to format every object in the user interface????
(3,202 Views)
Hello
You might try checking out some of the examples that get installed with CVI. And there is anot of good documentation available if you check out the help if you go to Start >> Programs >> National Instruments >> Measurement Studio >> Help >> MS Refernce. You should find svereral good references to make simple applications in CVI
And is a link to your CVI support page where you can find example programs and knowledgebases for CVI
http://www.ni.com/support/cvisupp.htm
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,202 Views)
