LabWindows/CVI
Plotting a text in the middle of a polygon
Hi
I have a polygon and a text field on a graph.
I would like to center the text field in the polygon. Therefore I should have the size of the bounding rectangle of the text.
I couldn't find an attribute giving this information.
Has someone an idea how I could achieve my goal?
Thank you
(2,737 Views)
A quick and dirty solution: use a (hidden) text message control with the same font and size you are using on the graph and operate based on the bounding rect of that control.
(2,713 Views)
Accepted by Bertrand_ENAC
Hi
Maybe the function GetTextDisplaySize() works for you.
Jan
(2,702 Views)
Thank you. Your answer was helpfull.
(2,610 Views)
