LabWindows/CVI
Print Last page blank , How to avoid last page to print , Using NiReport
Hi  all,
I am using  NIReport to generate the report/Print.
I have problem
I have one page to print,
I have written till the last line
Problem is that NI Report is adding a new blank page which is not needed.
This problem doesn,t occur when we don't write in  the last line or left blank.
Note : I have a header and footer details also
It will be printed on the blank page.
When NIReport  understand  specific text  is last line of page, then NIReport  automatically adding new page in  template .
How to avoid  to print last blank page in NIReport ?
Mukesh Kumar
(4,615 Views)
Accepted by mukesh121
Just a guess: are you using AppendLine? If so, you could try to switch to AppendText to write the line, adding NewLine as the first call when you need to start a new line. AppendLine add a new line to the report after printing the line, and this could generate a blank page if you are writing to the last line in the page.
(4,609 Views)
